USAXS: raw PV data from EPICS
written by: /home/beams/USAXS/Documents/eclipse/USAXS/livedata/pvwatch.py
date/time stamp: 2025-04-09 11:12:59
recent USAXS scans plotted
title scan file
EPICS process variables
name id description value units timestamp
usxLAX:pi:c0:m1.DMOV A2Rp_dmov motor done moving A2Rp 1 um 2025-04-07 07:16:48.769391
usxLAX:pi:c0:m4.RBV A2Rp_rbv motor ASRp, VDC -0.0012 V 2025-04-09 11:12:58.587329
usxLAX:pi:c0:m4.DMOV ASRp_dmov motor done moving ASRp 1 V 2025-03-16 17:59:15.146723
usxRIO:Galil2Bo0_CMD.VAL CCD_shutter USAXS CCD shutter 1 2025-03-16 17:59:34.197424
12ida2:EnCalc DCM_E DCM E, keV 21.0000 KeV 2025-04-09 10:08:39.795606
usxLAX:m58:c0:m4.RBV GuardBot motor GuardBot slit, mm -0.000 mm 2025-03-16 17:59:14.849032
usxLAX:m58:c0:m4.DMOV GuardBot_dmov motor done moving GuardBot 1 mm 2025-03-16 17:59:14.822260
usxLAX:m58:c0:m2.RBV GuardInB motor GuardInB slit, mm 700.000 mm 2025-03-16 17:59:14.740947
usxLAX:m58:c0:m2.DMOV GuardInB_dmov motor done moving GuardInB 1 mm 2025-03-16 17:59:14.713472
usxLAX:m58:c0:m1.RBV GuardOutB motor GuardOutB slit, mm -22.291 mm 2025-03-16 17:59:14.686565
usxLAX:m58:c0:m1.DMOV GuardOutB_dmov motor done moving GuardOutB 1 mm 2025-03-16 17:59:14.659515
usxLAX:m58:c0:m3.RBV GuardTop motor GuardTop slit, mm -0.100 mm 2025-03-16 17:59:14.794909
usxLAX:m58:c0:m3.DMOV GuardTop_dmov motor done moving GuardTop 1 mm 2025-03-16 17:59:14.767471
usxLAX:USAXS:I000 I000_amp_current I000 computed current, A 0.000e+00 2025-03-16 17:59:21.542083
usxRIO:fem04:seq01:gain I000_amp_gain I000 amplifier gain, V/A 1.00e+06 2025-03-16 17:59:22.057472
usxRIO:GalilAi1_MON.VAL I00_VDC ADC I00, VDC 2.5443 V 2025-04-09 11:12:58.972767
usxLAX:USAXS:I00 I00_amp_current I00 computed current, A 0.000e+00 2025-03-16 17:59:21.623301
usxRIO:fem03:seq01:gain I00_amp_gain I00 amplifier gain, V/A 1.00e+09 2025-04-06 20:02:45.844518
usxRIO:GalilAi0_MON.VAL I0_VDC ADC I0, VDC 2.5778 V 2025-04-09 11:12:58.972304
usxLAX:USAXS:I0 I0_amp_current I0 computed current, A 1.057e-08 2025-04-07 07:18:23.758001
usxRIO:fem02:seq01:gain I0_amp_gain I0 amplifier gain V/A 1.00e+08 2025-04-07 07:05:03.465781
usxLAX:m58:c0:m7.RBV I0_x motor I0_x position, mm -185.351 mm 2025-04-07 10:00:18.727077
usxLAX:m58:c0:m7.DMOV I0_x_dmov motor done moving I0_stage 1 mm 2025-04-07 10:00:18.727146
usxLAX:m58:c0:m6.RBV I0_y motor I0_y position, mm -0.000 mm 2025-03-25 08:38:47.957748
usxLAX:m58:c0:m6.DMOV I0_y_dmov motor done moving I0 position 1 mm 2025-03-25 08:38:47.957798
usxLAX:pic:m5.RBV M1TPico motor M1TPico, mm 174.990000 mm 2025-03-16 17:59:14.903538
usxLAX:pic:m5.DMOV M1TPico_dmov motor done moving M1TPico 1 mm 2025-03-16 17:59:14.876331
usxLAX:pi:c0:m2.DMOV M2Rp_dmov motor done moving M2Rp 1 V 2025-04-08 12:08:22.007195
usxLAX:pi:c0:m2.RBV M2Rp_rbv motor M2Rp, VDC -72.8436 V 2025-04-09 11:12:58.577189
usxLAX:pic:m6.RBV M2TPico motor M2TPico, mm -0.000000 mm 2025-03-16 17:59:14.957309
usxLAX:pic:m6.DMOV M2TPico_dmov motor done moving M2TPico 1 mm 2025-03-16 17:59:14.929995
usxLAX:pi:c0:m3.DMOV MSRp_dmov motor done moving MSRp 1 V 2025-04-08 12:08:22.012093
usxLAX:pi:c0:m3.RBV MSRp_rbv motor MSRp, VDC 56.6839 V 2025-04-09 11:12:58.583373
usxLAX:USAXS:SAD SAD sample-analyzer distance, mm 240.0 2025-04-05 14:54:49.697977
usxLAX:USAXS:SDD SDD sample-detector distance, mm 1085.0 2025-04-05 14:54:53.359616
S:SRcurrentAI SR_current APS storage ring current, mA 130.07 mA 2025-04-09 11:12:58.205152
usxLAX:m58:c0:m5.RBV Tcam motor TCAM position, mm 35.000 mm 2025-03-16 17:59:13.927300
usxLAX:m58:c0:m5.DMOV Tcam_dmov motor done moving TCAM position 1 mm 2025-03-16 17:59:13.900430
usxRIO:Galil2Bo14.VAL Ti_pf42_b3 USAXS Ti shutter PF42 bit3 None 2025-03-16 17:59:40.224770
usxRIO:Galil2Bo15.VAL Ti_pf42_b4 USAXS Ti shutter PF42 bit4 None 2025-03-16 17:59:46.225170
usxLAX:softGlue:FO18_BI Ti_shutter USAXS Ti shutter 0 2025-03-16 17:59:34.224466
usxLAX:USAXS:UPDsize UPDsize photodiode size 5.4 2025-03-19 10:40:15.019212
usxLAX:USAXS:I USAXS_I I, a.u. 7.8083e-18 2025-04-09 10:30:07.539438
usxLAX:USAXS:Q USAXS_Q |Q|, 1/A 1.0001e+00 2025-04-09 11:12:58.989892
usxLAX:dataColInProgress USAXS_collecting Collecting data 0 2025-04-07 07:18:24.563475
S12ID:USID:EnergyM.VAL Und_E ID E, keV 21.0392 keV 2025-04-09 11:12:58.914541
usxAERO:m6.RBV ar motor AR, degrees 1.240190 deg 2025-04-09 11:12:58.960910
usxAERO:m6.DMOV ar_dmov motor done moving AR 1 deg 2025-04-08 12:14:38.286487
usxAERO:m4.RBV ax motor AX, mm -312.558 mm 2025-04-09 11:12:58.956661
usxAERO:m4.DMOV ax_dmov motor done moving AX 1 mm 2025-04-08 12:14:38.287233
usxAERO:m5.RBV ay motor AY, mm -7.377 mm 2025-04-09 11:12:58.958678
usxAERO:m5.DMOV ay_dmov motor done moving AY 1 mm 2025-04-08 12:14:38.287290
usxLAX:USAXS:BeamActive.VAL beam_available 12-ID-C beam is available 1.0 2025-04-09 10:30:07.476759
usxRIO:GalilAi2_MON.VAL diode_VDC ADC diode, VDC 2.5504 V 2025-04-09 11:12:58.973003
usxLAX:USAXS:upd diode_amp_current photodiode computed current, A 2.618e-12 2025-04-07 07:18:23.758029
usxLAX:pd01:seq02:gain diode_amp_gain PD amplifier diode gain, V/A 1.00e+12 V/A 2025-04-07 07:18:18.678723
usxLAX:pd01:seq02:lurate diode_count_rate diode count rate (at last update), c/s 261756.78569 c/s 2025-04-07 07:18:23.757871
usxLAX:pd01:seq02:lucurrent diode_current photodiode last-update current, A 8.253e-13 A 2025-04-07 07:18:23.757906
usxAERO:m1.RBV dx motor DX, mm -167.478 mm 2025-04-09 11:12:58.947037
usxAERO:m1.DMOV dx_dmov motor done moving DX 1 mm 2025-04-08 12:14:38.287459
usxAERO:m2.RBV dy motor DY, mm -87.363 mm 2025-04-09 11:12:58.948948
usxAERO:m2.DMOV dy_dmov motor done moving DY 1 mm 2025-04-08 12:14:38.287514
usxLAX:SAXS:USAXSSAXSMode instrument_mode Instrument mode 1 2025-04-07 09:19:44.479599
usxLAX:alldone lax_alldone LAX motors moving 1 2025-04-09 10:43:45.667370
usxLINKAM:tc1:VACUUM linkamT96_Pressure Linkam Pressure, mBar 0.0 tbd 2025-04-05 15:31:27.222816
usxLINKAM:tc1:STAT:VAC:CNTRL linkamT96_VaccumStatus Linkam Vacuum Status 0 2025-04-05 15:31:27.222847
usxLINKAM:tc1:CTRLLR:ERR linkamT96_errors Linkam errors [ 78 111 32 69 114 114 111 114 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0] 2025-04-09 11:12:58.477413
usxLINKAM:tc1:SETPOINT linkamT96_limit Linkam Limit, C 40.0 C 2025-04-07 07:09:35.477257
usxLINKAM:tc1:STAT:LNP:PUMPING linkamT96_ln2Status Linkam LN2 Status, C/min 0 2025-04-05 15:31:27.222778
usxLINKAM:tc1:RAMPRATE linkamT96_rate Linkam Rate, C/min 200.0 C/min 2025-04-06 20:05:08.477388
usxLINKAM:tc1:STAT:HTR1:HEATING linkamT96_status Linkam Heating 0 2025-04-07 09:06:20.997841
usxLINKAM:tc1:TEMP linkamT96_temp Linkam T96 Temp., C 28.9001693726 C 2025-04-07 09:09:40.477511
usxLAX:ci94:errorByte linkam_errors Linkam errors None 2025-03-16 17:59:13.153457
usxLAX:ci94:setLimit linkam_limit Linkam Limit, C None 2025-03-16 17:59:07.153072
usxLAX:ci94:setRate linkam_rate Linkam Rate, C/min None 2025-03-16 17:59:01.152604
usxLAX:ci94:status linkam_status Linkam Status None 2025-03-16 17:58:55.152314
usxLAX:ci94:temp linkam_temp1 Linkam Temp. 1, C None 2025-03-16 17:58:43.145733
usxLAX:ci94:temp2 linkam_temp2 Linkam Temp. 2, C None 2025-03-16 17:58:49.146188
PA:12ID:STA_C_SCS_OPEN_PL.VAL mono_shtr_opened 12-ID-C mono shutter opened 1 2025-04-09 10:30:07.475825
usxAERO:m12.RBV mr motor MR, degrees -1.678903 deg 2025-04-09 11:12:58.977843
usxAERO:m12.DMOV mr_dmov motor done moving MR 1 deg 2025-04-08 12:14:38.286738
usxAERO:m10.RBV mx motor MX, mm -199.976 mm 2025-04-09 11:12:58.971987
usxAERO:m10.DMOV mx_dmov motor done moving MX 1 mm 2025-04-08 12:14:38.286919
usxAERO:m11.RBV my motor MY, mm 20.098 mm 2025-04-09 11:12:58.973775
usxAERO:m11.DMOV my_dmov motor done moving MY 1 mm 2025-04-08 12:14:38.287088
12idPyFilter:FL1:sortedIndex_RBV pf4_thickness_Al filter order 0.0 2025-04-07 07:17:03.974385
usxRIO:pf4:filterGlass pf4_thickness_Gl filter glass thickness in beam, mm 0.000 mm 2025-03-16 17:59:22.166140
usxRIO:pf4:filterTi pf4_thickness_Ti filter Ti thickness in beam, mm 1.250 mm 2025-03-16 17:59:28.189472
12idPyFilter:FL1:transmission_RBV pf4_trans filter transmission 1.0000e+00 2025-04-07 07:17:03.974846
usxLAX:sampleTitle sampleTitle SPEC sample title AMB5_40C_669min 2025-04-07 07:18:16.482571
usxAERO:m13.RBV saxs_x motor saxs_x, mm 67.907 mm 2025-04-09 11:12:58.979973
usxAERO:m13.DMOV saxs_x_dmov motor done moving saxs_x 1 mm 2025-04-08 12:14:38.287569
usxAERO:m15.RBV saxs_y motor saxs_y, mm -21.913 mm 2025-04-09 11:12:58.983963
usxAERO:m15.DMOV saxs_y_dmov motor done moving saxs_y 1 mm 2025-04-08 12:17:58.798607
usxAERO:m14.RBV saxs_z motor saxs_z, mm -136.620 mm 2025-04-09 11:12:58.982054
usxAERO:m14.DMOV saxs_z_dmov motor done moving saxs_z 1 mm 2025-04-08 12:14:38.287678
usxLAX:vsc:c0.S2 scaler_I0 scaler I0, counts 552037 2025-04-07 07:18:23.757726
usxLAX:vsc:c0.S3 scaler_I00 scaler I00, counts 0 2025-03-16 17:59:21.763730
usxLAX:vsc:c2.S2 scaler_I000 scaler I000, counts 27600 2025-04-09 11:12:58.653605
usxLAX:vsc:c0.CNT scaler_cnt scaler counting time, s 0.000 2025-04-07 07:18:24.518703
usxLAX:vsc:c0.S4 scaler_diode scaler diode, counts 1367162 2025-04-07 07:18:23.757781
usxLAX:vsc:c0.T scaler_t scaler counting time elasped, s 5.223 2025-04-07 07:18:23.757830
usxLAX:vsc:c0.TP scaler_tp scaler counting time preset, s 7.000 2025-04-07 07:18:24.521711
usxLAX:specFile spec_data_file SPEC data file 04_06_AMB5800.dat 2025-04-07 07:18:16.508010
usxLAX:userDir spec_dir SPEC data directory /share1/USAXS_data/2025-04/04_06_AMB5800 2025-04-06 19:58:41.468619
usxLAX:USAXS:macroFile spec_macro_file SPEC macro file None 2025-03-16 17:59:21.201413
usxLAX:specScan spec_scan SPEC scan number 1078 2025-04-07 07:18:16.482625
usxLAX:state state SPEC what is happening? USAXS moved to OpenBeamPath mode 2025-04-07 09:19:44.481452
usxAERO:m8.RBV sx motor SX, mm -159.639 mm 2025-04-09 11:12:58.968111
usxAERO:m8.DMOV sx_dmov motor done moving SX 1 mm 2025-04-08 12:14:38.287347
usxAERO:m9.RBV sy motor SY, mm -0.120 mm 2025-04-09 11:12:58.969960
usxAERO:m9.DMOV sy_dmov motor done moving SY 1 mm 2025-04-08 12:14:38.287403
usxLAX:timeStamp timeStamp USAXS macro timeStamp 2025-04-07 07:18:24.560576 2025-04-07 07:18:24.562751
usxLAX:m58:c1:m8.RBV uslith motor uslith USAXS slit horizontal gap, mm 1.6000 mm 2025-04-09 10:35:08.207927
usxLAX:m58:c1:m6.RBV uslith0 motor uslith0 USAXS slit horizontal center, mm -0.0000 mm 2025-03-19 08:22:27.476664
usxLAX:m58:c1:m6.DMOV uslith0_dmov motor done moving uslith0 USAXS slit horizontal center 1 mm 2025-03-19 08:22:27.476717
usxLAX:m58:c1:m8.DMOV uslith_dmov motor done moving uslith USAXS slit horizontal gap 1 mm 2025-04-09 10:35:08.207976
usxLAX:m58:c1:m7.RBV uslitv motor uslitv USAXS slit vertical gap, mm 1.6001 mm 2025-04-09 10:43:45.667130
usxLAX:m58:c1:m5.RBV uslitv0 motor uslitv0 USAXS slit vertical center, mm -0.3751 mm 2025-03-25 08:37:10.801154
usxLAX:m58:c1:m5.DMOV uslitv0_dmov motor done moving uslitv0 USAXS slit vertical center 1 mm 2025-03-25 08:37:10.801255
usxLAX:m58:c1:m7.DMOV uslitv_dmov motor done moving uslitv USAXS slit vertical gap 1 mm 2025-04-09 10:43:45.667276
usxAERO:m3.RBV waxs1_x motor waxs1_x, mm 12.019 mm 2025-04-09 11:12:58.950767
usxAERO:m3.DMOV waxs1_x_dmov motor done moving waxs1_x 1 mm 2025-04-08 12:14:38.287732
usxAERO:m7.RBV waxs2_x motor waxs2_x, mm -3.183 mm 2025-04-09 11:12:58.962791
usxAERO:m7.DMOV waxs2_x_dmov motor done moving waxs2_x 1 mm 2025-04-08 12:14:38.287785
PA:12ID:STA_A_FES_OPEN_PL.VAL white_shtr_opened 12-ID white shutter opened 1 2025-04-09 08:01:06.272630
data gathered by:
report page: $Id$
